Zum Hauptinhalt wechseln
Consumer-friendly laptop released in March 2005. The Inspiron 9300 is manufactured by Dell Inc. as a part of their Inspiron computer product line.
4 Fragen Alle anzeigen
S. M. A. R. T. test failure.
My Dell won't boot and the diagnostic disk said something about a S.M.A.R.T. test failure. What do I do?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
S. M. A. R. T. test failure means Hard Disk Drive is dead. So, you need to replace the HDD. I would recommend to replace it with Solid State Drive, because it's faster than HDD.
War diese Antwort hilfreich?
Bewertung 0
A S.M.A.R.T. test failure indicates that the hard drive is in a critical state. The most common error is that users fail to act immediately to back up all important data including: pictures, documents and any other files that need to be preserved. Backing up the hard drive should be done immediately. It is possible that some data has already been corrupted or completely lost. Once the hard drive has been backed up, it can be replaced.
The Dell Inspiron E1705 is a similar computer and the hard drive replacement
walk through can be used to replace the hard drive in the Dell Inspiron 9300. Removal/Replacement of Dell Inspiron E1705 Hard Drive
Bewertung 0
Antwort hinzufügen
Randy McMillan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 162
