Zum Hauptinhalt wechseln
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
371 Fragen Alle anzeigen
Replaced buttons, and now the 3D screen turns on, but stays black.
I removed the motherboard to get to the D-pad and to do so released the 3D screen ribbon cables, I put them back and ensured they are clean, tight and secure, flaps down. (twice- I went back and tried again after realizing the problem the first time.) and the 3D screen is turning on with the rest of the system (everything else is fine) but stays black. and tips on what I should do?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I know you had checked many times, but did you plug in the ribbon cables correctly? Some cables' copper side are supposed to be plugged to another side of connector.
This is the only solution this inexperienced person can think of, no guarantee this will work but it's worth a shot.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
This was it for me, since all of the cables for the upper hinge get rolled up, the LCD connector was backwards. Copper facing away from you if the bottom of the board is facing towards you. Thanks so much for this comment, I would never had tried it otherwise.
von
Antwort hinzufügen
vilanova2 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 65
