The side wheel is spinning backwards, how do I correct this?
The side wheel on my Roomba is spinning backwards, how do I make it return to its correct orientation?
Ist dies eine gute Frage?
The most common problem is an obstruction preventing the wheel from turning the correct way. The obstruction will need to be removed. The faceplate will need to be removed to fully access the wheel. Once the obstruction is cleared, the wheel should return to spinning the correct way. More details may be found here
War diese Antwort hilfreich?
The most common problem is an obstruction preventing the wheel from turning the correct way. The obstruction will need to be removed. The faceplate will need to be removed to fully access the wheel. Once the obstruction is cleared, the wheel should return to spinning the correct way. Additional information can be found on the troubleshooting page.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 95
