Zum Hauptinhalt wechseln
The Sony Xperia C5 Ultra (dual) is also known by the model numbers E5533 or E5563 and was released in August 2015.
Sony Xperia C5 Ultra touchscreen is malfunctioning.
Hello everyone.
I would really appreciate some help with my Sony Xperia C5 Ultra Dual since my screen is going crazy. The problem includes moments of normal function before it becomes fully irresponding or with Ghost touch.
Before you ask, I have removed an screen protector, rebooted the phone, removed the SD card and did a couple hard resets before realizing that none of these helps.
Thank you in advance!
Ist dies eine gute Frage?
Bewertung 5
3 Kommentare:
Brother, did you solve the problem? Im with the same situation, it is get me crazy!
von
are there any updates that need to be done. also i would try doing a full restore from a stock rom. not a hard reset. you can’t get more pure then reloading your system from scratch. any physical damage to the phone?
von
i also have the same problem, mine was due to rain but the effect appeared maybe almost half a year before it malfunction
von
Einen Kommentar hinzufügen
4 Antworten
I have the same problem but I always solve it cleaning the screen with a handkerchief and screen cleaning solution.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Really?? Does it help to bring it back to the normal state?
von
Definitely not, I have the same problem and cleaning it doesn't help at all. You should always use soft parts of your fingers in order to get the screen to respond.
von
I need for my sony Batteries?
Bewertung 0
2 Kommentare:
هاتفي عند تشغيلة تصبع الشاشة مقطعة ولا يظهر التطبيقات
von
الحساسات انضربن بسبب الماء
Bewertung 0
اهلا وسهلا من فظلكم مشكلتي في الهاتف لن يشغل فقط ضوء احمر في الشاشة عند تركيب الشاحن شكآ
Bewertung 0
Antwort hinzufügen
G008 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 3,809
