Zum Hauptinhalt wechseln
A 2-in-1 laptop/tablet with full 360° folding capabilities. Contains a 2.00GHz i7-5500U processor and was released in 2015 with model number 80JH000WUS.
20 Fragen Alle anzeigen
Why is my battery life less than expected?
When fully charged and unplugged from the charger, my laptop's battery dies within an half an hour of use. Basically, I need an outlet and my charger with me at all times if I want to get any work done.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi Kevin,
It's possible that either your battery is dead or your laptop charger does not function properly.
As batteries age, the repeated charging and depletion naturally lessens the battery's ability to hold a charge. If you need to learn how to replace the battery, you can do so with the guide Lenovo Yoga 3 14 Battery Replacement.
If your battery is not dead or dying, you may need to replace your laptop charger. It may no longer function due to natural wear and tear.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Kevin Millet wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 196
