Zum Hauptinhalt wechseln
Released alongside the Wii console on November 19, 2006, the Classic Controller is a simplified, non-motion controlled remote for the Nintendo Wii, geared toward classic gamers.
What type of screw is used in the end connector?
On the plug that connects this controller to the other controller, There is a clear plastic piece that is held on with two screws in a triangle shape. I need to remove this piece but I can't find a screwdriver with the correct tip to use. What size tip do I need?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sounds like a tri-wing screw. Would you post a photo?
Tri-point Y1 Screwdriver
Tri-point Y0 Screwdriver
The Y0 & Y1 are included in this set:
[verlinktes Produkt fehlt oder ist deaktiviert: IF145-028]
Similar to a Phillips, but with 3 blades. Precision fixed blade screwdriver engineered by iFixit. Bild
Produkt
$5.49
Three pointed screwdriver. Fits many tamper-proof three pointed fastener heads, including those found on MacBook Pro batteries. Similar to, and acceptable replacement for, Apple Tool 922-8991. Swivel top handle with precision tip driver. Bild
Produkt
$5.49
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I see I can insert a link but I don't see how to add a photo to the post. The Y0 Tri-point was correct. Thanks!
von
bryangarmon you can only add images to answers or question, not comments. Use this guide Bilder zu einer vorhandenen Frage hinzufügen to add images.
von
Antwort hinzufügen
bryangarmon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 595
