Zum Hauptinhalt wechseln
The Samsung Galaxy S5 NEO (SM-G903F) has a 5.1 inch Super AMOLED display with Full HD resolution. It's front and back cameras clock in at 5 megapixels and 16 megapixels respectively.
How do you get into this thing
AAAAAARRRRGHHHH
Someone help how the heck do you get into this thing?
this has turned into a nightmare I'm replacing the dock port on this I've already busted the screen (glass just came straight off the LCD but thats a whole different story)
I have also removed the 13 screws from the frame under then screen but i cannot get all the casing off the other side to get into where the motherboard & dock port is.
I have undone the clips on the inside of the battery recess but it all is stuck down tight i don't want to force it too much this repair has already cost me big time
Someone PLEASE help & point me in the right direction
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@inthebox ,Kenny, Link to partial tear down of the S5 Neo and a 2nd link which may have more info., Good luck.
Samsung Galaxy S5 Neo Display ersetzen
http://www.sonymobilephones.com/samsung-...
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Hi Thank you for that i did see that but it only goes as far as taking screen out not going in as far as getting motherboard out. Someone was kind enough to come & show me how. Its deceiving it looks like it should come away from the outer frame thats what i was looking at & couldn't figure it out it actually comes apart inside.
von
@inthebox ,Kenny, thanks for posting back, happy to here you had success with your device. Have a good day.
von
Antwort hinzufügen
Kenny Leonard wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 437
