Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
Is it possible to install a bigger HD into an 30gb iPod?
I'd like to know if it's possible to upgrade my iPod's HD once that i'll have to substitute it anyway.
So, I want to know if I can install a 80gb (for example) HD into my old 30gb iPod video (5th generation). In that case, is it possible to upgrade the battery to, or the batery for the 80gb iPod is to big?
Update
Why is necessary to change the headphone jack and de rear panel to?
By the way, i'm sorry for my poor english, but i'm from Brazil
Thanks for your patience!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
Actually, you can also install up to a 256GB SSD, but you have to make sure it is of the 3.3V type, not 5V.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Yes, you can upgrade to the 80 GB hard drive. You just need a few other parts also:
60/80 GB Headphone Jack
60/80 GB Battery
80 GB Rear Panel
Rubber Bumpers <---forgot about those the first time through
That is all you need to make the swap.
Update
You must replace the Rear Panel because the 80 GB drive is thicker than the 30 GB and your 30 GB rear panel won't fit over the 80 GB drive. Also, this is the same reason you need the 80 GB headphone jack. It has a longer cable to fit around the thicker 80 GB hard drive. This applies to the battery as well.
Includes headphone jack &amp; hold switch Bild
Produkt
iPod Video 60/80 GB Headphone Jack & Hold Switch
$24.99
Protect logic board from casing Bild
Produkt
iPod Video 60/80 GB Rubber Bumpers
Replace a broken or damaged 80 GB hard drive for your iPod Video with this part. Bild
Produkt
iPod Video 80 GB Hard Drive
$48.99
Shiny rear half of iPod / thick version Bild
Produkt
iPod Video 80 GB Rear Panel
$9.99
Replace a battery compatible with an iPod Video 60 or 80 GB. Model #616-0232. 850 mAh. Bild
Produkt
iPod Video 60/80 GB Battery
$14.99
War diese Antwort hilfreich?
Bewertung 11
1 Kommentar:
+ to the point
von
You almost got it matt- you forgot the rubber bumpers, those are essential, for a complete list of the parts you need check out this wiki page.
Bewertung 1
A fast and easy way to upgrade your iPod's storage is to get an iFlash mSATA adapter and an mSATA SSD of your choice of capacity. I've done this with my iPod Video and now have 128GB of storage available (more to come down the road!)
Bewertung 1
Antwort hinzufügen
Artur Lulai wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 8,508
