Zum Hauptinhalt wechseln
Der HP Officejet 6600 Tintenstrahl-Multifunktionsdrucker ist ein 4-in-1-Gerät, das drucken, scannen, kopieren und faxen kann.
Why is my printer only showing up to print faxes and not printing?
My printer doesn't allow me to print. I downloaded it again and all it does is show up as print faxes. What do I do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
1 Kommentar
Is the date and time on your computer holding when you are not on the internet?
von Teilen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
When you click on print there will be a box come up and in that box will be "printer" somewhere depending on the version of windows you have . Where it says printer there is a drop down box in there you will see different choices make sure you select the printer . The first on the list is usually the fax as things are listed alphabetically. Hope this helps
War diese Antwort hilfreich?
Bewertung 6
3 Kommentare:
There is no other choice, only the fax when I scroll down.
von Teilen
I have the same problem. Only option is to fax and when I try to print the "see what's printing" looks like it is printing but the machine thinks it is sending a fax. I have never had it set up with a phone line to fax. What changed and how can I get my printing option back?
von Teilen
Is anybody seeing these questions?
von Teilen
Remove the FAX Hp printer using disable driver options OR devices and printers from control panel. Then select the normal printer settings and enable that on network. That should take care of it. Usually these issues arise as you tend to install FAX using HP software.
Bewertung 0
Antwort hinzufügen
judygailtales wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 29
Insgesamt: 15,648
