Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
591 Fragen Alle anzeigen
Is this hinge a problem or not?
macbook pro late 2011 13 i nch
today i found out this : https://www.youtube.com/watch?v=nkWJ_T5I...
is this a problem? i looked inside i saw the hinde rod move back and forth
the hinge is stil steady tho at all angles the screen doesnt drop (the magneets pull it down tho when super close)
only thing is when i move it from when its almost close position it makes a slight noice but nothing anoying since that position isnt used alot
should i replace the hinge or not?
does this involve removing the glass? my glass panel does need a replacement so that can be a combined repair if needed
if wanted i can shoot a inside video tomorow
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
ok wil this fix it? i wil take it apart tomorow to paint the under site i wil take a look
von
Paint? just how beat up is his machine? How about a hard case?
http://www.ebay.com/itm/262237889185?_tr...
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
See step #13 of this guide. Put it in place and tighten the screws.
MacBook Pro (13 Zoll, Ende 2011, Unibody) Display austauschen
Remember, "if it ain't broke, don't fix it".
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
raymond1212 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 140
