My screen has w shaped vertical lines and odd colors
i try to take a photo , my screen has w shaped vertical lines and odd colors
Ist dies eine gute Frage?
@klj if the images that you take look distorted and have those color issues, it is most likely that your CCD sensor has failed. If they are just distorted on your display, you most likely need to replace the LCD. It will help if you post some images of what you are seeing, on your cameras LCD, with your question. For that use this guide. It will allow us to see what you see. Use these guides to work on your camera.
War diese Antwort hilfreich?
I think that the graphics IC is damaged, but it may also be a bad LCD.
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 313
