Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
Frage geschlossen
iPhone 7 no display after screen replacement.
hi i replaced screen on iphone 7 and after replacement iphone powers up, but there is no display
new lcd is fully working on other phone
lcd screen is genuine from another iphone 7
after connecting lcd connector didnt put any screws or metal plate on connectors for screen and home button ribbon
i used 2 screws and plate for front camera flex
phone is not in dfu mode
any help ??
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Your iphone light problem...... you need Check Hardware light Ways. i hope solve 100%
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Did plug off the battery during the installation? Otherwise your shorted your backlight circuit.
War diese Antwort hilfreich?
Bewertung 3
well there are a number of possibilities but it sounds like one of the connection ports may be corrupted or bent. if the screen works on other phones then check to see if the connection ports on the phone that does not work look exactly the same as the one that does. hopefully it is just a bend that can be adjusted with tweezers. i hope that this helps you and good luck on your repair
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 3,306
