Zum Hauptinhalt wechseln
Ein Controller mit Touchdisplay passend zur Nintendo Wii U Konsole. Es wurde am 30. November 2012 zusammen mit der Konsole veröffentlicht und war in den Farben Schwarz oder Weiß in jeweils dem Basic und Premium Pack verfügbar. Modellnummer: WUP-010 (USA)
Wii U GamePad buttons and touch screen not responding
My Wii U gamepad has been experiencing glitches with the buttons and touch screen. Only the R&L and ZR and ZL buttons are working. I tried to restart, neturalize the control sticks, and re-sync the console but nothing worked :(
The gamepad was fully-charged, cleaned and has no crack or any sort of damage done to it.
I haven't used it for over 5 months and I placed in at a safe location with nothing touching it.
I purchased my Wii U from Target in 2012.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
I have the same problem. My sons screen doesn’t respond to anything and therefore all the games that need to use the gamepad can’t be used!! We’ve replaced the battery, cleaner the cracks with a toothbrush, re set, re started many times and still nothing!!! Has anyone replaced the screen??
von
The LCD and touch screen are probably broken.
von
Einen Kommentar hinzufügen
10 Antworten
Gewählte Lösung
While I'm not an expert on the Wii U my first suggestion would be to unhook and reconnect the battery. This is easily done with a 00 Phillips screwdriver. The battery compartment is on the back of the gamepad and only has two screws if I remember correctly.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
I accidentally scripped one of the screws for the battery compartment, what should I do? D:
von
Here's a guide with tips on removing stripped screws
Wie man eine rundgedrehte Schraube entfernt
von
I did this, unhooking and reconnect he battery but nothing works, even in my Wii U pro controller , it is the same with hte wii u game pad. buttons are not responding. Can someone please help!!!???
von
Thanks Darcy,,,it worked!!
von
I recently had the same problem where none of the buttons worked on my wii u (including the touchscreen) except for the x, b and right analog stick. To solve it I took off the screen protector and put it back on and it worked properly so there must of been some contact it was sencing which interfered.
Bewertung 1
Want to update this 2020 , I have had the same problem and it's one thing that can cause these not working A,B,Y , touchscreen analogues and the D pad , I have had this problem on my partner's Wii u that I got her for Christmas , not sure if something has been dropped on it but here's what's wrong with your Wii u , if you have a screen saver take it off like what Lucas has said , if that has not worked look and examine your screen with a touch putting it left to right looking and the screen from every angle this is to make sure there is nothing trapped in the small gaps the screen has to the case , most likely you have something stuck in the gap if not there is a dent or deep scratch in your screen , if this has happened to you (The A is to accept something and the B is to go back this can not happen if you had your finger or pen on the screen because the console is processing it though the touchpad not the buttons There for if these buttons are not working but some are, its cause your screen has pressure so the console thinks your pressing it all the time
Bewertung 0
1-10-2020
I had the same problem. I bought it when it was released and have always kept it clean and in a safe spot on top of my dresser. It was untouched for months until I wanted to replay BotW. I went to the game and the only button that worked was Home. So I researched and came here for answers.
After I cleaned the screen the only buttons that worked were, Home, TV, Power, and B.
So I unscrewed the back of the gamepad, removed the battery for 30 secs, unplugged the power cord to the console, but nothing worked…UNTIL after trying to touch the BotW thumbnail for like 30 times, it finally reopened the game, and I was able to use all of the buttons.
My only problem now is that the gamepad keeps switching back and forth from the TV. I kinda gave the screen a massage with my fingers and it stopped switching.
Bewertung 0
1 Kommentar:
It's still switching...
von
I have the same problem. I disconnected the battery and my game pad doesn’t have a screen protector on it and the buttons are clean. The problem is using it during Mario Kart when you need to hold down the A button to drive. It works and cuts out every couple seconds even when I’m holding the A button down. I’m not really sure what’s wrong with it and I’ve tried all these suggestions, it’s only the A button that seems to cut out and do this.
Bewertung 0
I have the same problem, when I turn on my gamepad I can’t do anything, when I shake it, it does something, then it goes back to the same thing; I can’t do anything, once I finally manage to do something it messes up, when I played Mario tennis 64 the virtual console menu kept popping up in between matches, I haven’t fixed it yet so I really don’t know
Bewertung 0
1 Kommentar:
Who fixed it please tell
von
Mine has a heavy scratch and is not working. What do I do?
Bewertung 0
I got my gamepad fixed because I broke the screen somewhere like UBREAKIFIX and then the buttons on the right side stopped working. Only the right side, A, B, X, Y, Start, Select, right analog stick, R, ZR not working.
Bewertung 0
Same issue. Just bought a used one for my son. It comes on on the pad but won’t show on the tv and no buttons work except an and b and the touch screen isn’t working at all. Came here for solutions
Bewertung 0
1 Kommentar:
Hi, I ended up taking it into the game shop for repairs. It cost $100 but it was worth it. My son still plays the games.
von
Hey! My cousin passed his old Wii U down to me, I accepted it and now I can not really do a lot, but what I am doing currently is on the screen and spam click everywhere on the screen until I get to the button/game I want to go to, once I am in the game the buttons start working for some reason idk? And I am digging deep on the internet to make the screen more smoother, for me I am going to buy a Wii U stylus, so maybe you should try that. P.S. If you are having troubles typing, get a desktop keyboard and connect it to the USB port on the Wii U. It helps!
Bewertung 0
Antwort hinzufügen
dreamertiffanyliu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 74
Letzte 30 Tage: 201
Insgesamt: 36,518
