Zum Hauptinhalt wechseln
Das Samsung Galaxy S3 ist ein Smartphone mit Multitouch- und Drahtlosladefunktion, ist Eyetracking-fähig und hat einen vergrößerten Speicher.
I dropped my phone on the floor, the screen became black still working
hey,
I dropped my phone on the floor , then the screen became black , but the phone still working actually, I can hear the notification and the music etc ..
how can I fix in my home .. cause I really luv this phone .
THnxx ♥
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 64
31 Kommentare
Is the screen cracked?
von
yes , from the top of the phone .
von
While the glass may be cracked, check the corners carefully in the inner display of the screen. Usually there will be cracks in the corner if you can't find it.
von
mmm , I really didn't understand .
The cracks are in the right side from the phone on the top.
I can't find the inner display of the screen , I google it and I don't know how to find it . like .. Do I have to open the screen from inside or what ??
thnxx
von
and really i don't understand on mobiles and phones ..
von
26 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
7 Antworten
Gewählte Lösung
Hi Jessie,
This sounds like the inner AMOLED screen has been damaged, unlike lcd, when an AMOLED screen gets damaged, it tends to be blank and doesn't show anything.
For this, you would more than likely have to get the whole display (inner screen and glass) replaced, as they come as one unit bonded together. :-)
War diese Antwort hilfreich?
Bewertung 34
13 Kommentare:
Ok thank you ..
von
How?
Can i do that in myhome?
von
yea can i do this at home? i have a iphone 7
von
maybe no one will answer my question but I still want to ask. I know lcd and amoled are different. Is it still correct if I ask something like "can you repair my phone's lcd" even though my phone have amoled one. English is not my first language so I'm afraid if the shop technician got confused. But I am also pretty sure they understood it. What I undestood from the comment was, amoled is like lcd brother, both of them are screens/display but they just have different types of specification. I am using Samsung galaxy A7 (2018) btw
von
I have a trac fone the screen is black scrambled how much would it cost to have it fixed
von
8 weitere Kommentare anzeigen
You will need to replace the LCD and digitizer. Luckily, ifixit sells one for $200. The item code is IF225-004-1.
Bewertung 9
6 Kommentare:
Ok thank you ..
von
@pccheese read teh comment left by GED. Not an LCD but AMOLED read about the differences on here Does not require backlight is a great benefit...:-)
von
Yes, I knew about ammoled/led, I was just saying LCD because that's kinda the generic word for display in my mind. It doesn't really matter in most phones that use LCDs because the LCD is normally fused to the backlight so it's one unit, just like an ammoled.
von
The backlight isn't really fused as much as a LCD or amoled is to the glass, as it's actually quite easy to remove the backlight and replace that (like in iPhones), since it's only usually held to the LCD with a small amount of double sided adhesive, and the soldered connection, where as removing the glass isn't that easy, due to the OCA (Optically Clear Adhesive), unless you have the correct equipment.
iPhone will be heading for Amoled displays next year I believe, so things will be changing!
von
Where not talking about iPhones. This is a Galaxy S III.
von
1 weiteren Kommentar anzeigen
If your phone's screen is black but the phone is still working, try these steps:
1. Force Restart: Hold down the power button and volume down button (or the appropriate combination for your phone model) to force a restart.
2. Check Connections: If you're comfortable, open the phone and check if the display connectors are securely attached.
3. Inspect for Damage: Look for any visible damage to the screen or connectors that might need professional repair.
If these steps don't work, you may need to replace the screen or seek professional repair services.
Bewertung 6
4 Kommentare:
very hepful thank u
von
Genius mind.
von
The screen went black on my Galaxy sS21 after I dropped it. I tried your first tip of forced restart and it worked! Thank you sooo much! You're a lifesaver!
von
I dropped my Samsung from the hight of hips against concrete. The screen went black and your first suggestion worked. It saved me about $150. Thank you!
von
This is the sort of thing you need to buy ( obviously match it to your own phone model) it is a replacement for the screen and the LCD (as most of you refer to it) ( the thing that displays the image and senses touch.
before i start describing what can be done let me give you some context on my phone.
It is one of those phones that cannot be opened from the back and where you cannot remove the battery and where the sim card is inserted through the side.
One day i dropped the phone, it hit the concrete on its back at first it was fine. After a while the screen slowly started turning black from the bottom, as time went on more and more of the screen started turning black. It kinda looked like my phone was bleeding internally. anyway everything worked except the display. the phone was fully responsive all physical and touch buttons worked and the phones sound system still worked . Once the black screen of death took over 3/4 of my screen, the phone was still fully responsive, but using it became more of a guessing game, trying to remember where all the icons were. the next day the screen was totally black but still responsive.
https://www.aliexpress.com/item/10050014...
this one is for the phone that i have a Samsung J530. you can replace it at home. before you buy anything check the phone model. if you are unsure of your phone model and can’t find which one it is exactly and just refer to it as by the generic term that it was advertised as, like mine was called Samsung J5 but if you click the link there is 3 different types with different arrangement of electronics, you can do the following to know exactly what you need.
I attached photos to help visualise what i’m going on about but just remember that i already cut off the broken LCD from the electronics and threw it in the trash before writing this
  1. take off your glass screen. it will be glued on so it will take some force. try to pry it up from one of the broken corners (those are where usually cracks happen)
  2. pry up the LCD. this is also glued and unlike the screen it is glued not just around the edges so to take it off you will have to break it (a lot) there will be shards jumping around so i advise you wear eye protection.
  3. you will see the electronics attached to a connection point or you might see it hide behind a tab like in mine. detach it. the inly thing you need to detach are the electronics that are connected to your LCD, leave everything else as it is.
  4. now search for an touch screen digitizer for your phone model and with the correct electronic component within those models. try to match up the electronics strip to the one that you have ( photo added of mine for referance ( sorry if it’s a bit small ))
  5. i purchased mine from aliexpress. i know that sometims it says that it doesn’t deliver to you country like it did for me, in which case still search on aliexpress just from a different seller. should hopefully work. i got my LCD for just under £14 ( including shipping)
  6. when your LCD arrives connect the strip to the connection port, you should feel sort of a click and it should hold sturdy. gently glue the LCD to place and then gently glue the screen back on.
Bewertung 2
2 Kommentare:
Omg I have the exact same problem with the exact same phone. Did it work for you later after you replaced the screen?
von
yes, it did. The phone worked like new after I replaced the screen.
von
i dropped my phone and my samsung A32 galaxy went black,i tried to force restart it but it wont work and it stills vibrates
Bewertung 1
1 Kommentar:
@keniohan „ and it stills vibrates“ is a clear indication that this is a broken display. Replacing the screen should fix your phone
von
"It sounds like the display might be damaged. You should consider contacting a professional for repair or replacing the screen yourself if you're comfortable with it. Good luck!"
Bewertung 0
3 Kommentare:
@samratrajput people are coming here for help and not to be send to a repair service. This can easily be accomplished by anybody that is somewhat comfortable with repair.
von
Thanks for the detailed guide! After dropping my phone, the screen went black but still works. I’ll try restarting and checking connections as you suggested. Much appreciated
von
If you drop your phone and the screen goes black but the device is still working, the issue is likely with the display. It could be a loose connection or a damaged LCD. You may need a screen replacement to fix this problem.
von
If your phone screen is black but the phone is still working, you can try the following steps to fix it at home:
1. Restart the Phone:
- Hold down the power button for about 10-15 seconds to force a restart.
2. Check for Loose Connections:
- Gently press around the edges of the screen to ensure there are no loose connections inside the phone.
3. Connect to an External Display:
- Use an HDMI adapter to connect your phone to a TV or monitor to see if the display works on an external screen.
4. Perform a Hard Reset:
- Consult your phone’s manual or search online for the specific hard reset method for your phone model. This typically involves holding a combination of buttons (e.g., power + volume down).
5. Check for Physical Damage:
- Inspect the screen for any visible cracks or damage. If the screen is physically damaged, it might need a replacement.
6. Battery Removal (if possible):
- If your phone has a removable battery, take it out, wait a few seconds, and then put it back in before restarting the phone.
If these steps don't work, you might need to replace the screen. Screen replacement kits are available online, but this requires some technical skill. If you're not comfortable doing this yourself, consider taking it to a professional repair service.
Bewertung 0
Antwort hinzufügen
Jessie Calvin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 68
Letzte 7 Tage: 537
Letzte 30 Tage: 2,745
Insgesamt: 381,663
