Zum Hauptinhalt wechseln
The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
51 Fragen Alle anzeigen
Is it possible to apply Thermal Paste?
I saw some thermal pads on the N8's mid-plane. Now my phone will auto-restart and continue restart when the phone is in warm environment but it will be all right if getting it directly under an aircond. So, I was thinking will apply thermal paste helps this. Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sounds like that'd work, there's a similar issue with older HP laptops which only have thermal pads and then overheat and continually restart- the solution is to apply thermal paste. The thermal pads alone aren't good enough for keeping it cool, so thermal paste will help you out there. You can get some thermal paste here, and here's a guide for installing it.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Hi, thanks for your reply. I had a thermal paste which I used for my PC. I will go to Nokia Care first before I done anything on it (it's still under warranty). If they failed to fix it, then I will try to find those screw drivers to open up my Nokia N8 and apply them.
von
You may want to read this article
http://www.engadget.com/2010/11/18/nokia...
von
I read that already. Thanks. I had sent for warranty and have to wait around 1 to 3 weeks for the motherboard to arrive.
von
Antwort hinzufügen
Peng Fong Er wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 2,631
