Zum Hauptinhalt wechseln
Sudden refusal to charge
After a couple of years of 'no problem' day to day' use, my Nexus 9 has suddenly died. I don't think think it was 'mid use death' , it hasn't been dropped etc and is in excellent condition.
I suspect that it ran out of battery and now is refusing to charge. I'm not even getting the white flash when in a very low battery state.
Before I buy a replacement battery, does anyone have any suggestions?
Ive tried every combination of button pressing to boot to different states, bit I suspect it's a batter issue.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
I have no suggestions except replace your battery. I'm pretty sure that your battery is completely dead.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
Just a quick update, my new battery arrived today, fitted it and booted first time.
von
Yay!!! Glad your phone is back to working condition :)
von
Phone? The Nexus 9 isn't a phone, it's a tablet. I don't even think it has 3G/4G capabilities. What do you mean?
von
David. Just a question. Where did you find a Nexus 9 battery? It is a nightmare to find....
von
Hilfreichste Antwort
@davidtjackson you may want to check that your chargers working . Check your cable try it with another one, check the port that theres no lint or dirt preventing the cable from connecting properly . If you have access to another charger try it . You may also want to reseat the battery as it can sometimes just need to make a new connection to work again and recharge. These are a few things Id try before buying a new battery. Hope this helps
Bewertung 3
Thanks both,
I've managed to rule out it being a faulty cable. I've found a replacement battery - so hopefully it'll be that. I'd have expected it to last longer than a couple of years, but I suppose these things just die every so often.
Bewertung 0
1 Kommentar:
Glad to help. And sadly yes, rechargeables only have so many charges in their lifetime.
von
Antwort hinzufügen
David Jackson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 26
Insgesamt: 504
