Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1233 Fragen Alle anzeigen
lcd screen does not respond on right corner
previous screen this phone works fine, but when my cell phone fell to the floor the lcd screen is not cracked but, the lcd screen is not respond on right corner. i dont know what should i do for this problem to fix my phone, should i change the lcd screen or not? anyone can help solve this problem? thanks before
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
7 Kommentare
Reseat the screen connections for the screen. If it still does not work then the screen has gone bad (make sure to unplug battery before doing so.)
von
@benjamen50
i have doing that, unplug and plug it again the lcd connector but i forget to unplug the battery before doing that. whether there will be a problem?
von
It's recommended you unplug the battery because blowing the backlight circuit is a possibility if it's still plugged in.
Anyway you can conclude the screen has gone bad.
von
okay thanks @benjamen50 it means I have to replace a new one lcd?
von
Yes. New screen. LCD is fused with the digitizer.
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi Luthfie,
Take a look at this guide, step 14, to reseat the connections, like Ben recommended.
I think Ben is right. If you have followed Ben's instructions but the problem is still there, you have to replace the digitizer/LCD. The corner that is not working any more might be the corner that hit the ground. So, this part of the digitizer might be gone.
I would like to encourage you to at least try a repair yourself. You don't need to be a real professional to do that. Just follow this guide here on ifixit. Give it a shot! Always keep in mind: First switch of your iPhone and then remove the battery next.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Luthfie Rachman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 97
