Zum Hauptinhalt wechseln
Alles was du brauchst, um dein iPhone zu reparieren! Von den neuesten iPhone 15-Modellen bis zum allerersten iPhone überhaupt - bei iFixit gibt es kostenlose Anleitungen zum Reparieren und Zerlegen für jedes iPhone und dazu auch die besten Ersatzteile, Werkzeuge und Tipps in der Galaxis.
36478 Fragen Alle anzeigen
Error On iPhone 5s Activation
My Ip5s just had a "searching problem" on network, i tried to reset it and failed to activate it, a messege appeared "...COULD NOT BE ACTIVATED BECAUSE ACTIVATION SERVER IS TEMPORARY UNAVAILABLE.." I tried to connect it to itunes but it displays "iphone" all the time. Tried to reboot it by holding Home and Power button but still failed to display itunes plug. Please help me fix my problem, I did everything i know but still dont work. Anyone please help me, you're answers are highly appreciated. Thank you very much.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
This happened while you were in the middle of using your phone? It was already on, and everything was normal?
von
i phone 5s is showing “iPhone is disabled connect with the itune”
Please explain steps to reset the iphone 5s.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Reset it again.
Make sure you SIM is in, doesn't matter if the SIM is active. Connect to wifi, then connect to your PC and iTunes. No idea why but some phones need the trifecta of SIM, wifi and iTunes to activate.
War diese Antwort hilfreich?
Bewertung 2
DFU restore - check flex cables - try new charging port & battery & screen - clean LB in ultrasonic if not Probably hardware, which is all but improbable to fix .... is it a customers phone ?
Bewertung -1
Antwort hinzufügen
renee anne bartolabac wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 235
