Zum Hauptinhalt wechseln
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
SD Card reader doesnt work anymore..
I've lift the sd card reader out because I couldnt get the sd out but when i've replaced it, my nintendo didn't detected it anymore, is there any possibilities to fix that ?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@yumi , Yumi , Yes the SD card reader is replaceable, You should first check it and clean/blow off dust/etc. then clean contacts with a Qtip dampened with Isopropyl Alcohol, then reseat to make good connection and try. Also look for any damaged contacts that you may be able to straighten carefully with a tooth pic. If you can try a few different compatible SD cards to rule out bad SD card also. Below I will post a link showing how to remove the SD card and a link to a replacement part if needed, which you can also do a search for to get better pricing perhaps. Good luck.
Nintendo 3DS 2015 SD Kartenleser Austausch
https://www.amazon.com/Gametown%C2%AE-Me...
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
firstly thanks a lot for your response,
i tried simply to clean it as you said but i didnt see any part who were really damaged, unless maybe the ribbon cable, i might have moved it a little by removing the sd card reader the first time, i shouldnt have tried to open it myself..
i dont have any Isopropyl Alcohol but i'll try if i can buy some,
anyway, thanks for your help, and excuse my bad english level, that's not my mother tongue-
von
Yumi , Thanks for replying back, you will want 90% or higher Isopropyl Alcohol found at big box stores or any drug store as it will not damage electronics. Worse comes to worse, you may have to replace the part. Good luck with your 3DS.
von
Antwort hinzufügen
Yumi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 276
