to start, the iphone 6 is not waterproof in the first place. i would suggest against using it in the rain, that gasket is to keep the button aligned with the orifice it belongs to, while maintaining a springback feel. (not the only mechanical part that offers this.
However, being inset in the device can be a cause of a couple things.
1) Loose screws on the mount
2) The flex does not fit properly on the folded circuit
3) The glass is manufactured thicker than the standard Screen glass.
4) the screen's plastic frame is not manufactured correctly.
5) multiple of the above.
There is a possibility that the adhesive on the rubber gasket may fix your issue, but i would guarentee it, as i replace home buttons on iphones regularily, and it is usually a manufacturers flaw on the screen when i see this.
Hope this helps!
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar
Any idea where what kind of glue/adhesive I can use to get it to stick again? Also useful to make other flex cables stick again after having peeled them off.
Currently, I only have double sided adhesive tape.
von Didier Daniel
