The car is not moving it is making a sound when engaging gears
Ist dies eine gute Frage?
@larrylk , Kelerile , You do not state auto or standard transmission which would help. If every thing seemed fine and you see no fluid leaks and transmission fluid levels good, you may have broken a CV joint(constant velocity joint) not allowing wheels to drive when one breaks. This is not the only thing that could cause this though, transmission,clutch,differential,etc could be bad. Have a good technician have a look and diagnose and estimate repair. Good luck.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 55
1 Kommentar
@larrylk what exact model is your HOnda? Engine size? Manual or automatic?
von oldturkey03
