fans on full after GPU reflow
Hi
brought a macbook pro with GPU problems and have fixed it with a reflow, but when when install the OS and even reset the SMC it runs really slow even with a SSD and 16gb of ram in it.
Can anyone help???
Ist dies eine gute Frage?
12 Kommentare
Okay it's the Th1h right fin sensor
Anyone know where that is
von Matt
There are sensors inside the GPU, most likely this is bad. Honestly, a reflow won't be a permanent fix, especially on this model. The GPU itself is bad and will fail again, so don't bother selling it if you do fix it, you don't want that on your conscience ;)
von Reece
Hmm on Adt test and Asd test the gpu passes ... might clean everything and try again
von Matt
@capsitup sorry, read this as the 2011 15" model (common GPU issues), not the 13".
Haven't heard of that code before, but there is a PCH T29 Proximity/FinStack area on the thermal sensor page of the schematic, so I would recommend checking this area out if you have experience with logic board repairs (your board view is 820-2936, Google for schematic and board view files).
Did you run ASD EFI version to give you the exact errors? OS version and the built in version will not give you as much detail.
von Reece
okay so its the q5501 thats at play will order and pop the chip on
von Matt
7 weitere Kommentare anzeigen
