Zum Hauptinhalt wechseln
Die PlayStation 2 wird oft als "PS2" bezeichnet. Sie kam in Japan im März 2000 heraus. Reparaturen erfordern nur ganz normales Werkzeug, sind aber manchmal etwas trickreich.
199 Fragen Alle anzeigen
Disc read error or general issue with game?
I recently purchased half-life for the PS2 and once I reach one of the loading screens the game crashes with a black screen and when I reset the system it says disk read error it has repeatedly black screened at this pointed the game.....is there an issue with the disk or is it a genuine disk read error ? Also I saw a guide to open the system clean the lense and adjust some gear will this solve my problem?
If anyone is curious to see what the game does I have a screenshot of it and additional info it is the original fat model
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
This is a common fault on the original PS2, it stops reading blue discs, you'll need to replace the laser, follow this guide
PlayStation 2 Lasereinheit im optischen Laufwerk tauschen
good luck..
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
rayeasom thank you for your answer I was led to believe that this could be fixed by messing with some gear inside the system, I am glad I waited for an answer on here before pulling apart my system with incorrect knowledge and lacking a crucial replacement part...I will be giving this my best attempt once I acquire a replacement laser assembly thanks again!
von
Antwort hinzufügen
csilva12 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 587
