Zum Hauptinhalt wechseln
The Kenmore Elite HE3 is a washing machine by Kenmore.
669 Fragen Alle anzeigen
High speed *only* on Drain/Spin cycle
I have a Kenmore Elite HE3t washer model 11044932200 that isn't getting up to a high speed spin on any of the washing cycles. It only gets to high speed on the drain/spin cycle. There are no codes at the end of the washing cycle. I've already opened the filter for the drain pump and didn't see anything clogging. Running it through a diagnostic cycle, the washer drains quickly.
I watched a load go through the rinse and drain/spin cycles. It appears that it can get a load balanced and spinning at low speed without shaking but for some reason, decides to stop and try to rebalance. I checked around the rubber ring and there's nothing in there to obstruct spinning either.
After the washing load finishes, the clothes are very wet. When I put it on Drain/Spin cycle, it spins at high speed, drains, and the clothes are just slightly damp at the end, as expected.
Also note that the motor was replaced a little over a year ago, and the drum & seal was replaced about 5 years ago. Thanks for any suggestions that might help me zero in on the problem!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Yep, that fixed the problem. Thank you very much! When I put on the new belt it was very tight and I thought it might be the wrong part. I double checked and the part numbers matched for the belt I was replacing. The old one didn't show wear or damage but apparently had stretched out over time.
I also replaced the pressure switch along with the belt because my wife said she saw a F9 error code last week. I don't know if the two problems were related in any way but I'd say that the belt was the primary cause of this problem.
von
Does anyone know what is wrong with my Maytag 4000 series when it spins but does not go into the full high speed drain the drain is clear checked it
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Cause 1
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
rersek wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 2,800
