Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für die Apple Time Capsule Modell A1302, im Wesentlichen auch gültig für das Modell A1254.
Time Capsule powers on but wont boot.
Basically, i had a power outage and after I got power, the LED would flash green for like a second and then go out. I opened it up and found 2 caps that bloated so I replaced them. Now it will turn on, the fan spins for a little bit, there is an odd sound coming out of the power supply, and the HDD won't spins up. After a minute or so, the sound stops and there is just a blinking, orange LED on the front. Anyone have any ideas? If nothing else, can someone get me a pinout of the pins so i can power it with something else
@mayer @danj @oldturkey03 @lpfaff1
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
To solve this, I first opened it up and removed the power supply following this guide Tausch des Netzteils einer Apple Time Capsule Mod A1302
I found 2 bloated (dead) caps on the board and replaced them, although I replaced them it still didnt work.
I just decided to use an old computer power supply to power it and as I didnt use the hard drive for anything, I just removed it and powered only the board.
The guide i found for the pinouts is here.
What are the power supply pinouts for the 500gb time capsule?
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Cameron wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 1,584
