Zum Hauptinhalt wechseln
Die fünfte, auf Android basierende Generation der Galaxy Smartphones von Samsung ist seit dem 11. April 2014 auf dem Markt. Zu den Verbesserungen gehören der Fingerabdruckscanner, eine erneuerte Kamera, ein größeres Display und Wasserresistenz. Es ist in vier verschiedenen Farben verfügbar: Schwarz, blau, weiß und kupfer.
577 Fragen Alle anzeigen
My phone keeps flicker yellow on n off
My gelesy s5 keeps flicking in n out yellow how do i fix it
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Usually this happens right after the phone is dropped. If it is then you will need to get the screen replaced.
War diese Antwort hilfreich?
Bewertung 2
*Hello, if you have an Android device, and if you enabled Developer Mode and selected an option that gives you a visual screen update flash, this is why. Please turn off the "Show Screen Updates" and/or "Show GPU view updates" and/or "**Show hardware Layers updates"
*Please note, these instructions only apply to Android Devices, if you do not have an Android device, or if your phone has visible damage, the screen's pixels may be disfunctional.
  • *According to the developer options screen, the Show Hardware Layers Updates makes hardware layers green when they update, and this may be causing your issue.
Bewertung 2
My phone did the same thing and turning off auto-brightness fixed mine.
Bewertung 1
2 Kommentare:
If you continue to have people give their opinions on fixing your phone it would help tremendously if you can understand what that person is saying, I can't understand what the &&^& these @%^$$@$# are saying, get a person that doesn't sound like they just learned English as a 4th grade refugee!
von
Stop with censorship, people know what I meant when you add these $%^&**^^ crap to hide my potty mouth...you &&^&^$ @%^$$@$#!!!
von
Mt phone is half yellow and it glitching then turns black and the top half of phone is normal
Bewertung 0
1 Kommentar:
Hi Mackenzie,
That sort of behavior is almost always a result of a damaged or defective LCD screen. To fix the problem you'll have to replace it. iFixit has a guide showing you step by step how to replace the screen and can even sell you the part you need if you want!
Samsung Galaxy S5 Display Einheit ersetzen
von
Antwort hinzufügen
Carol Butler wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 74
Insgesamt: 12,845
