Zum Hauptinhalt wechseln
The second generation of the Recreational Active Vehicle with 4-Wheel Drive, commonly known as the RAV4.
21 Fragen Alle anzeigen
Rear door metal rubbing creates a squeaking noise when in motion
How can I definitely diagnose and resolve this kind of issue? Horizontally opening door.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
draclif, I have read in a few forums it may be door seal/weather strip rubbing and making that sound, spray weather strip/seal with some silicone lubricant and also spray the rubber hatch stoppers. If rear window also opens separate from the hatch do it as well. Still getting a squeak, open hatch/window and put a very light coat of WD40 on the shafts of the lift struts and lube all hinges and latches.
Just a thought, if it has a rear tail gate hung spare tire, check that the tire is secure and also check hanger for worn/ loose hinge/latch/bushings, replace if worn parts are noted and lubricate generously. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thank you! I'll give that a try and let you know. This model RAV4 rear window is stationary so I'll go with the stripping and stoppers.
von
Hi all RAV4 owners with this problem.
This problem with RAV4 backdoor is always actual. Thanks for previous comments and advices.
I resolved problem on my RAV4 2005 with replacing original rubber bumper in upper corner of the door with bumper from old VW golf II which has spiral slot on side which goes on the door hole and with rotation of that bumper it is very easy make optimal position.
Sorry on my bad English but want to share this trick.
Regards from Bosnia!
Bewertung 0
Antwort hinzufügen
draclif wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 12,138
