Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Why is it just showing a black screen after lcd replacement.
After a replacement of an unresponsive screen but still showed everything working the screen is completely black. I had my iphone lcd replaced and it did show at first a dim light on screen when turned on. i tried unplugging the battery then turning it back on but all it shows is a black screen. i know the phone still works because when i plug my phone up i can see a light through the crack on the inside. i think my backlight shortage is out from not unplugging the battery first from removing the four plugs but i need to know what to order to replace it, like a new logic board or backlight screen. :it doesnt show an apple logo when trying to turn on either
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
You probably have a defective LCD. Take it back to the person who fixed it (if you didn't do it yourself) and have it replaced under warranty.
If you need to purchase a new one you can find one here: iPhone 6 LCD and Digitizer
iPhone 6 LCD and Digitizer Bild
Produkt
$69.99
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
I got another apple screen tested to see if it was a defective lcd from a professional and it still showed just the light on the inside when plugged up so thats why i think its a backlight but i dont know what i need for it.
von
Hold a flashlight over the display, if it's the backlight on the display, you'll be able to see the home screen and what not. Pretty sure, if it's the backlight circuit, you won't be able to see any light. If you life up the display you can see the backlight off the side on the back
von
@cvneutron Zieminski! Cool to see you on here!
von
@cvneutron The legend coming through with great insight. Most likely an LCD issue. I agree with @imedic that it could be backlight fuse or coil issue, but that should be covered under a warranty as well
von
Back light ic chip might have been pop if the battery was not unplugged during repair or trace damage from long screw damage. I would clean the connectors and test screen again
Bewertung 0
1 Kommentar:
I tried cleaning it, its still just a black screen.
von
This could be a wide range of things from a defective LCD stated to your connector plates on the logic board they are very fragile and if bent will not work properly. My suggestion is if you did this yourself is look at your quality of replacement and that might be your solution and make sure you ordered the right model number a 6 digitizer might not work with a 6s phone and vice versa
Bewertung 0
Antwort hinzufügen
bethany huff wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 81
