Car is not starting
I have a Citi Golf 1.4i 2000 model, I turned into my drive way and realised the engine had stopped running, the starter is cranking perfectly but the engine is not catching at all, what could be the problem here please help???
Ist dies eine gute Frage?
7 Kommentare
Have you tried spraying starter fluid into air intake while having someone trying to start it?
von Cameron
No I haven't but what I've just done is I pulled out the inlet pipeline that comes from the fuel pump and turned the key on to see if fuel spouts out but nothing happened, is this a sign of failure?
von Thulani
Hi,
Check that the fuel pump fuse (#5 I think) and Fuel pump relay (J17 position #2) in engine bay fuse box are both OK
von jayeff
Thank you jayeff
von Thulani
Hi i have a velociti 1.4i 2005, drove it 9ne day the next day it didn't want to start due to flat battery then I jump started the car and it started I drove around the block fine parked it and the next day it didn't start it just swings fine but no sound of starting and I feel like I don't hear the fule pump like I used to and I checked the fuse inside no12 and it was fine apparently there is a relay as well not sure where it is
von Damian Snyman
2 weitere Kommentare anzeigen
