Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Call microphone issue after couple days
Hi,
Have a customer device iPhone 6.
There was issue with bottom microphone. Call receiver didn't hear anything.
So fist I change flex with microphone.
Working great for 2 days than call receiver hear customer very bad.
I change flex again from other source and after 2 days bad microphone sound comes again.
Anyone have same issue?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
This is a very common porblem of the iPhone 6. If the replacment of the charging port flex cable doesn´t solve the problem you need to replace the Cirrus Logic 338S1201 Audio Codec IC. In many cases this solved the problem if the error appeared after the iPhone hit the ground.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
While you're right about this. It doesn't really explain why a replacement part would work temporarily. Also, if board level repair is the best option. Maybe we can refer these guys to someone. I heard iPad Rehab is good, and they have a mail in service
von
@theimedic it does explain why the replacement part works temporarily. If the iPhone hit the ground or something else (like this) the balls of the chip suffer under this hit. These balls can be completely disconnected or even get faulty. Try this. Use the phone until the error appears and then cool it down. If it works again the problem is caused by defective soldering balls. A simple reflow can fix this or a replacement of the IC.
von
Wouldn't a cold solder joint make that part never work? Not temporarily? Reflowing the bga is temporary fix, at best
von
I'll reball it and let you know about results
von
Antwort hinzufügen
hawaiiek wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 69
