Zum Hauptinhalt wechseln
Eighth generation of the Honda Civic.
58 Fragen Alle anzeigen
Bottom front panel is loose
The bottom front panel of my isn't fully attached along the sides (by the wheels), probably due to parking a bit too close to the curb a few too many times. The panels keep popping out along the sides. Any suggestions for how to get them to stay put?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
zlisto , You may have to purchase new plastic push rivet retainers (Link below)or if they are lower ones that cannot be seen, perhaps you can use the medium size pull ties. If the lower valance holes are worn to a larger size and held by bolts or screws insert a larger washer to prevent pull through. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.amazon.com/Partsam-Fender-Re...
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
zlisto wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 613
