Zum Hauptinhalt wechseln
Eine sanitäre Vorrichtung zur Entsorgung menschlicher Abfälle. Kein Klempner notwendig! Eine Toilette zu reparieren ist unkomplizierter, als viele denken.
How do I stop s running toilet
How do I stop the toilet from keep running slowly after flushing?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
@allankjel,Allan, Probable bad flapper or fill valve. A worn/faulty flapper could be the issue by allowing water to leak past. A failing fill valve can prevent a toilet tank from filling properly, or cause the toilet to fill continuously. The toilet flapper opens to allow water to flow from the toilet tank into the bowl when the toilet is flushed. Afterwards, it closes as the toilet tank fills back up. If water is constantly flowing from your toilet tank, chances are your flapper is not functioning properly and will require a replacement. Link below is a installation guide for replacement flapper and fill valve. A lot of plumbers will suggest to change both at the same time as insurance, as one fails very possible for the other piece to fail in near future, and the replacement parts are normally low cost. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Toilettenklappe austauschen
Toiletten-Füllventil austauschen
Toilet Klappe Bild
Anleitung
Schwierigkeitsgrad:
Leicht
5 - 10 minutes
Toilet Füllventil Bild
Anleitung
Schwierigkeitsgrad:
Mittel
10 - 15 minutes
War diese Antwort hilfreich?
Bewertung 4
Sometimes the main reason behind the running toilet is the toilet fill valve, so I think if you get a good toilet fill valve you can relieve your fill valve problem.
Bewertung 0
You can provide your water flow control with the adjustable float in your water tank. You should carefully control the float adjustment. If you set it too high, your filling valve will not close. You can get detailed information from Best Toilet Fill & Flush Valve ; you can choose the most suitable valve for you.
Bewertung 0
Did you got the answer?
If you are still wondering check here.
Bewertung 0
1 Kommentar:
I'm looking for the workings of a slow motion toilet top sold with Toto toilets, One side seems to have lost the connecting mechanism and the seat now slams down on the toiler. The lid still closes slowly.
von
Best Flushing Toilets You will also need a replacement fill valve and toilet flapper. Examine the Fill Tube. A weak flush or nearly empty bowl occurs when your tube is disconnected. Set the Fill Height by Examining the Float. Set the Handle and Chain of the Toilet. Repair Any Bent Lift Arm in a Toilet. Get a New Flapper for Your Toilet.
Bewertung 0
Antwort hinzufügen
Allan Kjelstrom wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 53
Insgesamt: 4,710
