Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
787 Fragen Alle anzeigen
no power, dim magsafe led
liquid spill.
disassemble and cleaned thoroughly with 99% alcohol.
no power. any chance at all that is not the logic board?
if the dc-in board was fried, would the machine power on?
i do have a previous gen 2.26Ghz machine. does it use the same dc-in board?
if it is the logic board, any sources for component level repair?
tia
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
I'd remove the logicboard, soak it in 99% alcohol, dry it after a few hours in the oven (wrap in alumium foil and use something around 100 degree centigrade). After that have good look with a magnifier for any residant stains and clean the manually. Assemble and keep your fingers crossed.
I rescued a few liquid victims that way.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
If the DC-in board was fried then as long as the battery had power it'd boot up, which is a likely possibility, batteries are some of the first things to go after a liquid spill, the first thing you should do when you spill is yank the battery out- unfortunately the new MacBooks require a little more time than the turn of a quarter :(.
So if you can test with another battery that'd be a good idea, otherwise I'm sorry to say it's the logic board, which 2/5 times is the problem after a liquid spill.
Bewertung 1
2 Kommentare:
turn of a quarter would have been much quicker than going out to find a tri-wing!
will try another battery and post again. your reply is greatly appreciated. :)
von
Tried good (charged) battery: does chime. no video, fan runs, did not hear the hard drive trying to load os. Connected external monitor using dongle: no go. anyone have clues? other diagnostic ideas? tia
von
Same problem. 1 glass of red wine = no power. were you able to get yours going?
Bewertung 0
Antwort hinzufügen
mega wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 1,916
