Why is it so slow to charge
It take 8 to 12 hours to charge
Ist dies eine gute Frage?
dustyrob456, Possibly faulty battery/connection, weak charger or perhaps loose/dirty or damaged charge port. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connection(Qtip dampened with 90%+ Isopropyl Alcohol) and reconnect/install battery, still not charging battery probably faulty. Below is a guide that will get you access to battery, connections and enable you to check for other possible loose/bad connections and components. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,387
3 Kommentare
Could you take a picture of the sicker on the power supply?
Bilder zu einer vorhandenen Frage hinzufügen
von George A.
It has no sticker on it sorry
von dustyrob456
Is it a USB power adapter? If so, does it specify the amperage? Such as 1A, 2.1A?
von George A.
