Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2375 Fragen Alle anzeigen
replaced battery will not charge
Hi, got a new battery and replaced it per instructions, ran the battery down below 10% as instructed, tried charging it, nothing happened, used 3 different cord on wall charger, also tried my car charger and nothing, connected to laptop to see if the computer saw the device, still nothing, any ideas? removed battery a few times to make sure the plug was right. any other way to charge the battery besides using the 30 pin connector?
Thanks Greg
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This can be three different things. Two easy, one bad news.
First this is faulty charging port. If the device is on but no charging connection, this charging port component will need to be replaced.
iPhone 4 Dock Connector ersetzen
There is a difference in charging port between CDMA and GSM models. Make sure you get the right one.
Second thing could be a faulty battery. Although this is more unlikely aince the battery does seems to operate.
Third, if all else fails is motherboards issue, which you will need to contact a professional for advise on how to repair the device.
Happy repairing!
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Greg Wischmeyer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 53
