Zum Hauptinhalt wechseln
Das Samsung Galaxy J7 ist auch als Samsung Galaxy J7 Duos bekannt, es hat einen doppelten SIM-Karten-Slot. Es kam im Juni 2015 heraus und verfügt über ein 5,5-Zoll-Kunststoffgehäuse und ein 720 x 1280 Pixel großes Display sowie Android OS, v5.1. Es hat eine 13-MP-Hauptkamera und 5-MP-Sekundärkamera sowie einen herausnehmbaren Li-Ionen-Akku mit 3000 mAh.
170 Fragen Alle anzeigen
Dropped phone in water, works fine but battery makes sizzle noise
I accidentally dropped my phone in water (toilet), immediately took it out, washed/rinsed it quickly, and took out the battery and SIM card and dried it. After a while, I tried the phone, and everything works fine except the SIM card being undetected and a constant sizzling sound whenever the battery is in. I tried putting in another battery to see if the battery was the problem, but the sizzling sound was still there. I don't think there is any liquid corrosion damage, as the phone was in contact with water for less than around 30 seconds and the back inside of the phone was barely wet, but I think there might be something wrong with the place where the battery connects in the phone (the four yellow pointed things). For now im going to let it dry and try the battery again. What should I do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Christian Liam sounds like you are cooking something. Either a component, water residue under or near a component or the battery. I suggest that first you do not turn on your phone, charge it or try to connect it in any way. Remove the battery from the phone to minimize further damage. After that completely disassemble your phone by using these guides. Using 90%+ isopropyl alcohol, clean your phone by following this guide. It was written for an iPhone but all the points are still pertinent to your phone as well. While cleaning, check for obvious missing or damaged components. you can always post some images of your boards etc. with your question so we can see what you see. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that.
Once it is properly cleaned, replace the battery and reassemble your phone. then you can properly troubleshoot.
iPhone Bild
Anleitung
iPhone Wasserschaden reparieren
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
iFixit Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Christian Lim wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 17
Letzte 30 Tage: 101
Insgesamt: 13,658
