Zum Hauptinhalt wechseln
Der Xbox One Wireless Controller Modell 1697 wurde 2015 veröffentlicht. Er ersetzte das Controller-Modell 1537 und behob einige der Probleme, die bei diesem auftraten. Der Controller Modell 1697 verfügt über eine integrierte 3,5-mm-Kopfhörerbuchse, die die Kompatibilität mit den meisten Headsets von Drittanbietern ohne einen zusätzlichen Adapter ermöglicht. Dieser Controller wurde eingestellt und durch das Modell 1708 ersetzt.
3.5mm mic not working but can hear others.
I can hear other people but they can't hear me, when I blow or talk into the mic my ring around my profile lights up like I'm talking. I've tested the mic on other devices and works. I've tried other mics but same thing happens. It's a turtle beach headset.
Ist dies eine gute Frage?
Bewertung 1
6 Kommentare
Does it work on other XBOXs?
von
i am having the same problem. i can hear everyone, but no one can hear me. i have tried the cheap one that came with it, the newer one that uses the new port, and a Turtle Beach XO3. i am fearing it is my controller.
von
It's not the controller because I have a brand new controller and headset and still have this problem.
von
So, any answers for this problem?
von
@dtr20 by "Ring around the profile" do you mean you are using this on a PC with discord? If so, I'd check your discord settings first, because if discord talk indicator is lighting that probably means audio is reaching it. If you are not on PC, please explain what you mean in the comments below.
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Check your settings to see if your microphone is set to mute or the gain is really low. That should fix your issue as your xbox is definitely picking up audio but is not sending it to people at a high volume.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
The Xbox is not recognizing that it's even plugged in.
von
Do you have another controller to test your headphones with? You could just be unlucky and got a defective controller.
von
I'm having the same issue. 3.5mm jack, brand new control and turtle beach headsets for the Xbox one. I can hear others, they can't hear me. I'm not muted, all my settings are correct, and others are even hearing themselves but not me.
Bewertung 0
1 Kommentar:
Any answers to this? Really frustrating
von
I’m haveing this problem also
Bewertung 0
Try going to settings, accessories, and see if your controller needs an update (very weird I know but worked for me with this issue)
Bewertung 0
Antwort hinzufügen
Jake Amato wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 27
Letzte 30 Tage: 123
Insgesamt: 24,618
