Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Microphone not working during calls, voice notes and headphones
Hi:
I'm having some trouble with the mic of my iphone 6. Is not working during a phone call (caller can't hear me), taking a voice note, neither Shazam app can recognize any noise/song. The mic was replaced and suddenly stop working, so I started to use the headphones and problem solved.
Siri is functional using the headphones and without them. I read that Siri's mic is located near ear speaker so that's why Siri can hear me.
I've erased resent downloaded apps, hard reboot, verified the mic connection and don't find what's happening. Last thought, the headphone Jack, lightning connector, mic assembly has damaged only the mic.
What can I do to solve this problem?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
The microphone for calls is on the Lightning cable. Its not uncommon at all for them to go bad. Its not common for both to go out at once but...I've seen weirder things.
Replace the Lightning cable and you should be all set.
iPhone 6 Lightning Connector Einheit ersetzen
iPhone 6 Lightning Connector and Headphone Jack
iPhone 6 Lightning Connector and Headphone Jack Bild
Produkt
$19.99
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I think that calls microphone is not in the lightning cable or you're talking about the assembly (the recommended part to be replaced)?
von
Its in the assembly.
von
Antwort hinzufügen
Krd wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 715
