Trying to print from my iPhone 6 I am connected to wifi but no luck w
How do I make my esp7250 AirPrint
Ist dies eine gute Frage?
I dont think that model supports airprint.
just to confirm, wireless printing is a different function to 'AirPrint', which is Apples own version.
It will only be supported if it expressly says 'Airprint compatible' on your printer.
You can troll through the menus to confirm this, but from the spec sheets I've seen, it doesn't look to be supported.
You can do one of 2 thing if it doesn't natively support AirPrint functions.
1 - You can download an app on your Mac that allows AirPrint functions. The issue is, this Mac needs to be running to get the iPhone to print, as it effectively works as a forwarding service, phone to mac to printer.
2 - You can buy an AirPrint enabled ethernet adapter. This would require plugging the adapter into the printer via the ethernet adapter, then when you print, this adapter will broadcast the AirPrint over your network instead of the printer.
Most Kodak printers support an email service now-a-days though, so if all else fails, you can use that. Typically, when you setup your device, you can give it a unique email address. Whenever you email a photo pro a document to this email address, it will print it direct, as long as the printer is turned on and connected to the network.
i hope this helps.
War diese Antwort hilfreich?
If you have a WorkForce series, download the Epson iPrint app.
This has its own internals that lets you browse and print web pages, print photos already on the phone, print pdfs, and scan to the phone or email.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 34
1 Kommentar
Do you have a Stylus Pro or a Workforce?
von S W
