Zum Hauptinhalt wechseln
Die Apple Watch Series 1 ist eine Überarbeitung der ursprünglichen Apple Watch, sie wurde am 7. September 2016 angekündigt. Die meisten Teile sind die gleichen wie bei der Series 2
120 Fragen Alle anzeigen
Can I Repair my iwatch
Wanting to know if this is fixable...
Apple Watch Series 1 had small crack on screen then was submerged in water.
It still worked after but battery was low, same day I charged watch it got extremely hot and never turned back on... I'm afraid I fried something!
What if anything needs to be replaced in order to fix it?
I have nothing to lose... already ordered my daughter a new one.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Sorry guy it doesn't sound good here. While the Apple Watch is waterproof it's not when you have a broken screen or other void in the shell where water can enter.
The fact the watch is getting hot implies the circuitry inside had gotten wet. The only question is how bad and if replacing the display alone will fix things. You might also need to replace the battery.
Here's the IFIXIT teardown for the Series 2 which is the same for the Series 1 (not the original though its different): Apple Watch Series 2 Teardown.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Nicole Kubenka wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 1,115
