Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
591 Fragen Alle anzeigen
Is my hard drive dying?
My Macbook is a great computer and I love it, but for quite some time now it cannot do anything without spinning that frustrating color wheel. I can't even get through typing this without seeing it. This happens when I open or close programs and applications when I'm on the internet pretty much all the time. A few days ago I backed up to an external hard drive to reformat the computer in hopes it was just crammed with junk and needed a good cleaning. This did not work, if anything it has gotten worse. The RAM shows to be ok, I have 4 gigs, and will probably upgrade that in the future as well. Really don't want to spend the money on a new computer if I can easily fix this one with a new hard drive and some upgraded RAM.
Any answers are appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I had faced the same problem in past and used the ways to overcome this but it works for me. I think you must try once again.
von
Check out this site it might be helpful. https://gmdrives.com/best-portable-exter...
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
On a side note, how full is your HDD? Loading issues, such as you are describing, can start to occur if your HDD is near max capacity. Try cleaning out your HDD of excess files and unused apps, and see if that helps. Doing a reformat and restore was a good idea, and gets rid of any excess temp files, however you will still need to go through your long term files (photos and etc), to really clear up space. If that doesn't work, I would go with the RAM upgrade next. If your computer habits involve heavy usage apps, or having a ton of browser tabs open, that could also be slowing down your computer. Chrome in particular, especially when having 20+ tabs open can significantly slow down a computer.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I backed up up the pictures and my documents to an external hard drive and did not put them back on, I don't have a ton of apps and generally have 5 to 6 tabs open in safari at a time. According to my disk utility I have 497 gigs of 500 available. It takes a while to boot up and the entire time I have been typing this the page has been frozen. I constantly see the spinning wheel of frustration.
von
Most likely a hard drive/IR cable issue. Replace with the one from the 2012 model.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
MacBook Pro (13 Zoll, Mitte 2012, Unibody) Festplattenkabel austauschen
If the condition last to long it starts destroying the data on the hard drive and necessitates a backup and reformatting of the drive.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Bild
Produkt
$34.99
Bewertung 0
Antwort hinzufügen
Tim wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 173
