Zum Hauptinhalt wechseln
Kam im Juni 2016 auf den Markt, in Europa anhand der Modellnummer A3003 zu identifizieren, in China und Nordamerika mit A3000 (entsprechend https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
66 Fragen Alle anzeigen
Sudden shut down and not able to switch it on
I was using my oneplus 3 and it randomly shut off. It wont respond to anything. Battery charged 90% enough for 10hrs . Tried pressing power button and volume down buttons same time, for factory reset it wont respond. I faced no such issue earlier. Everything was fine till now. Please advise.
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
Wait till next day for the battery to drain completely .then charge again.
von
I kept my phone in fridge for 20-25 min. then tried to plug in to dash charger n started pressing on/ off button several times and tried plugging unplugging cable while pressing on/off button n mobile got switched on
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Mine does this. The way to fix it is press the ON button while plugging it it and keep it held down while you unplug it and then plug it back in again. That always fixes mine. Don't ask me what causes it to shut down in the first place though.
War diese Antwort hilfreich?
Bewertung 7
7 Kommentare:
OMG this really worked for me! I have no idea why, but it does!
I only registered for this website to say thank you and confirm this solution :)
von
Worked for me too. No idea how does it work. And yes I also signed up to say thanks :)
von
How its work anyone tell me.
von
I just signed up to thank you! You saved me a lot of trouble! I am eternally grateful to you!
von
Can confirm this works on a 3T as well. I don't know how you figured this out, but THANK YOU!
von
2 weitere Kommentare anzeigen
I am using one plus 3 phone but it often switched off automatically . And when I gng to switch on some times it's not respond and some days 10-15 days working good and some days daily 10-15 times is going on switched off pls anyone give suggestions wat I will
Bewertung 1
Have you tried the unbrick guide from the OnePlus forum? It may be a software issue, and if so then the first method in the unbrick guide should solve it. :)
https://forums.oneplus.com/threads/guide...
Bewertung 0
Antwort hinzufügen
POTHUMUDIS wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 20
Letzte 30 Tage: 86
Insgesamt: 10,792
