Zum Hauptinhalt wechseln
Apple brachte das verschlankte und aufpolierte iPad Air am 1. November 2013 in den Versionen Space Grau und Silber auf den Markt. Es beinhaltet den A7 Prozessor und kann mit 16, 32, 64 oder 128 GB Speicherkapazität gewählt werden.
577 Fragen Alle anzeigen
iPad Air Charging issue...
When hooked up my iPad Air does not show a charging symbol. Im not sure if the battery is dead or if the charging port is malfunctioning. How could I know to order the correct parts? There has been no previous damage to the iPad.
Thanks,
Andy
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
That is the conundrum DIY fixers face. If you haven't already done so, open up your iPad. The battery is usually the part that needs replacing. Still, once you have removed it you can probe it with a multimeter to see if it is holding a charge. At ~4.2V, it is pretty much full and at 3.5V it is pretty much empty.
If the battery is holding a decent charge and you're not getting the charging symbol, you may have a defective charge port or logic board issue. If the battery is dead, then it's probably the cause (but it could still be something else). If it looks like a charge port or logic board issue, it will require a micro-soldering repair and is not DIY.
Ultimately, the only way to know is to try known-good or new components.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
andystills wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,671
