Zum Hauptinhalt wechseln
Modellnummer A1707. Veröffentlicht im Juni 2017, erschien dieses MacBook Pro mit Kaby Lake Prozessoren mit bis zu 2,9 GHz quad-core Intel Core i7 Prozessoren, mit Turbo Boost bis zu 3,9 GHz.
327 Fragen Alle anzeigen
Damaged case, everything works. How much $ to fix?
Dropped on R corner. Upper case, lower case and screen case bent. Top and bottom separated. Speaker damaged. Have apple care but not +. Too late to add + and too late to get credit card to cover damage. What will it take to replace cases? I know-lots of $, but where, when and how can I find, purchase and replace these damaged parts?
Everything else works perfectly and no damage to the screen itself. Dropped from only 1-1/2 foot.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
[image|1191605][image|1191602][image|1191604]
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I'll give it a try
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Getting parts at this time will be nearly impossible. Until
they become available, use an add on plastic hard case
Bewertung 3
5 Kommentare:
I forgot, if a machine is still covered under the original warranty, you can still buy an extra two years worth of Apple Care.
von
Thanks for the reply. After looking at the tear down for this unit I'm not sure I even could replace the damaged case halves and the screen lid if the parts ever become available. I didn't imagine dropping it in the 1st place so no AppleCare +. Just a very unlucky hit and a cautionary example of how vulnerable these units are to major damage from a small inadvertent moment of inattention. But, again, everything still works. I'm glad of that.
von
mikenmary8 If you would please post some pictures of the damage so we can better evaluation the extent of the damage, how much is cosmetic and what it would take to get it functioning correctly.
von
I've got some good pictures but I don't know how to add them. I've explored the site looking for some instruction but to no avail.
von
Antwort hinzufügen
mikenmary8 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 1,209
