Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
798 Fragen Alle anzeigen
How do I fix the apple screen loop?
I replaced the logic board, hard drive cable, battery, and the hard drive with an SD card adapter. It restored and in disk mode was able to load music back on no problem. When I exit disk mode and try to use the iPod, it goes to the apple screen, turns off, and goes back to the apple screen, then turns off... over and over.
I don't really know what else I can replace, but figure someone here probably knows more than I do! The SD card reader is the iFlash Solo and the SD card is a 64GB card referenced as working on my model on the iFlash site.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Just check the ribbon connector to the Iflash card is connected properly and when you inserted a Sd card it should give a clicking sound.
If it still doesn’t work it could be a faulty iflash card
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
And when you restore the ipod the ipod should itself restart and just check the hold button should be off position
von
Antwort hinzufügen
John McPherson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 58
