My Screen Pops up
Why is my Screen on my Tab Pro popping up near the cable connection to charge tablet? Please hel. Ty
Update (09/25/2017)
Thank you also home button is loose ty
Ist dies eine gute Frage?
Looks like the battery might be swelling, be on the lookout if you decide to open it up for a swollen package in the middle of the case.
War diese Antwort hilfreich?
My Samsung tablet is lifted on the corners and home button. Will not stay down when pressing. It turns on but is stuck on a message about google?? Would battery replacement fix this?
Thank you.
It could be the battery swelling up which is bad because it can lead to explosion and more problems.
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 42
Insgesamt: 8,068
3 Kommentare
Cynthia Avey could be that it is separating from the frame. It will help if you post some pictures with your question. That way we can see what you see. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that
=== Update (09/25/2017) ===
Thank you for the images. This could be the screen requiring replacement but it may also be the case starting to bend. Lay the Galaxy on a straight surface. If it is bowed in the center, it is bend. If it is not, it is your display needing replacement
von oldturkey03
Not bowed in center only where the home button is, it is bowed only there.
von Cynthia Avey
Just found out it is the battery
von Cynthia Avey
