Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
5 Kommentare:
Hi,
Has it worked OK before when connected to the computer?
Does it work OK if you try to copy or scan a document using the printer's control panel?
If it works when using the printer's control panel, what make and model of computer is it connected to and what OS is installed in the computer?
Hi,
von jayeff
Printerhead? what do you mean? or are you trying only to print from your pc?
von jbermudez27
Yes. It is not printing from computer or copy or fax
von lorenzo.walker
Hello jayeff,
It is not printing from computer, or fax, or copy. I have replaced all ink cartridges in printer
von lorenzo.walker
Hi lorenzo.walker,
Have you tried a 'Clean Printhead"operation from either the printer's control panel or the HP printer software in the computer?
On the printer press the Right Arrow > Setup > Tools > Clean Printhead.
Do it 2-4 times to see if it starts to print.
von jayeff
