Zum Hauptinhalt wechseln
Hyundai's entry-level vehicle. It's available only as a sedan; the hatchback was discontinued after the 2017 model year.
My front bumper is coming loose
I recently bout a used 2015 Hyundai Accent. The dealer pointed out that the front bumper was coming loose, and that it would be repaired. When I picked it up, he said that his guy had put a clip on it to fix it, and it did look repaired. Now it is loose again, and I am afraid that if it rubs up against something, it may get worse.
Before I go through the hassle of trying to get the dealer to repair the problem again, how could I fix the problem myself. It is on the passenger side, and the plastic separates for about 7 inches.
Thanks!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
gatewaynomad post some images of your loose bumper so we can see what you see. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that. Most likely it is your bumper cover that is coming off. This from the manual:
  • Loosen the radiator upper cover mounting bolts and clips.
  • Remove the mounting clips.
  • After loosening the front bumper side’s mounting screw, then disconnect the side’s.
  • Push the lock pin, disconnect the fog lamp connector (A).
  • Remove the front bumper.
  • Installation is the reverse of removal
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
That is exactly what I wanted, thank you!
von
My left side bumper is also apart sticking out looks like missing a clip or broke clip.
Bewertung 0
1 Kommentar:
Follow the same procedure listed above if you have the same car.
von
Antwort hinzufügen
gatewaynomad wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 11,726
