Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Why does my phone "die" at random times even on 100 percent
My iphone 5s doesn't have any hardware issues but for some reason my phone shutdowns out of nowhere on any percent and gives me the (dead plug in phone) indication
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
I have an iPhone 6 and it shuts down on any percent
von
mine is a 6 and yet does the same, i’m so sick of it
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Have you attempted to replace the battery? Most likely it will need to be replaced.
It could, but really rare, be the battery is not communicating to the board properly. This will require performing a DFU and charging the phone to 100% after completion. However, that just depends on the age of the battery. If it's old, just do a replacement.
Guide for Convenience
Part from IFixIt
iPhone 5s Battery Bild
Produkt
iPhone 5s Battery
$29.99
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Honestly I think only a restore is required instead of DFU as that can fix battery percentage reading issues.
Op: Make sure to backup your iPhone to iTunes first before restoring it of course.
von
You are correct, a back up and restore should happen first before running the DFU. Sorry for skipping a step.
von
i had this problem with my i phone 6splus, and i got the battery replaced twice but then came to find out it was a software problem so you’ll have to get a new phone :/ don’t waste your money on the battery if it’s really consistent
Bewertung 0
I have been having this problem with my blackberry priv. Is it the same fix?
Bewertung 0
Antwort hinzufügen
jake lopter wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 8,618
