Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Modell A1311 / Mitte 2010 / 3,06 & 3,2 GHz Core i3 oder 3,6 GHz Core i5 Prozessor
333 Fragen Alle anzeigen
What part do I need for iMac Intel 21.5" EMC 2389 CPU Heat Sink?
I have seen the how-to schematic and it states no parts needed. Does ifixit.com have the parts needed for this endevour? If so can you send me a link to them? Help please!
Thanks
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
Why are you replacing the heat sink?
The guide is intended for someone to apply a fresh coat of thermal paste and cleaning of the heat sink fins.
How about giving us the full rundown here on what your problem is, it might be something very different!
von
Well my heat sink is overheating and need to change it. The power supply heat sink is overheating and I decided to change rather than buy another iMac.
von
@fixbit - Double check using a good sensor monitoring app like: TG Pro. Paste a screenshot of the main screen for us to see here.
von
Einen Kommentar hinzufügen
iPhone LCD Display Fix Kits
Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
Kits kaufen
Reduziere die Reparaturkosten, nicht die Qualität.
Kits kaufen
1 Antwort
Hilfreichste Antwort
Replace the thermal paste. The heat sink is just a hunk of metal.
iMac Intel 21,5" EMC 2389 GPU Karte austauschen
Wie trage ich Wärmeleitpaste am besten auf
Arctic Silver Thermal Paste
UPDATE
If the heat sinks are overheating on the power supply changing them will not help. You need to find the electronic component that is overheating, The heat sinks are just metal vents used to disperse heat, they don't fail. Use an IR gun to help identify the offending component.
IR Thermometer
IR Thermometer Bild
Produkt
IR Thermometer
$19,99
Arctic Silver Thermal Paste Bild
Produkt
$8,99
Electronics Skills Bild
Anleitung
Schwierigkeitsgrad:
Einfach
5 - 20 minutes
iMac Intel 21.5" EMC 2389 GPU Karte Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
50 minutes - 3 hours
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
docromaniac wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 64
